whomadewho wrote:WDRacing is correct - Rust out! Jonathan1173. Really courious,how did you manage to remove the Phillips screws that hold the cap in place?? I have a miss fire in number 4 tried briefly to remove the screws,looks like It could turn into time consuming project.
Whomadewho,
It has been quite time consuming, as I've had to tear down to the pistons and build up from there. Numerous delays to source/ save up for parts.
After the system is de-pressurized and fuel rail had been removed, I placed the rail on the bench. A good dose of PB Blaster, overnight soak, wiped dry, then used Vise-Grips held perpendicular to the screws. (Rail laying flat, visegrips straight up and down).
I used a pair of channel-lock pliers to close Vise-Grips onto the screw as tight as possible, then twisted grips using large screwdriver wedged in between the two handles of the grips.
Needless to say, I DID NOT re-use the screws. Home depot stocks machine bolts, M5 0.8x 20mm I think. Just take the old screws and match them up.
Found some re-man Beck-Arnleys on Rockauto for under $30 apiece, get 'em before they're gone.
