modulation »
https://forums.nicoclub.com/modulation-u72502.html
Sun Sep 07, 2008 10:27 am
I'm serious about this..
Unplug the spark plug wire from your spark plug with the engine running on each cylinder (1 cylinder at a time.)
If the problem is on a single cylinder, when you pull the spark plug wire for that cylinder the engine won't run as different (or different at all) as when you pull the spark plug wire on the other 3 cylinders.
The car will sound bad/almost die with the other 3 cylinders unplugged, but if it doesn't run much different with the spark plug wire unplugged then the problem is probably located in that cylinder. Then check the spark plug and injector on that cylinder.
If the problem is a bad fuel pump or clogged fuel filter then doing this won't make a difference so at least then you'll know it's not a indvidual cylinder that has a problem.
