Injector O-ring + Lube Question.
newdude1
K well I just installed my injectors and everything, but when I was putting the box away that the injectors came in I noticed a little thing of lube. So it got me thinking and I search on here and sure enough it says to use the lube on the o rings. So do you think that since I didnt use any that my o rings wont seal right? Cause a leak or maybe even flood the injectors?
jr_ss
Car: 95' S14
The only issue might be a leak. The lube is there to facilitate the install of the injectors.
newdude1
Has anyone ever installed new injectors with out using anything? I just curious if anyone else has had an issue when not using any lube.
duffman1278
Car: 89 240sx Hatch, the wildcats!
If you don't lube them they'll tear up right away. I know....
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I installed mine before realizing the need for the lube but I haven't had any problems.
bruinbear714
If you don't use lube during install you run the risk of ripping the orings or crunching them.
newdude1
Ya I redid it with some lube. Thanks.
