s13 k3nrock »
https://forums.nicoclub.com/s13-k3nrock-u90667.html
Mon Mar 30, 2009 3:51 pm
ok so i have been searching and searching for this for like 2 weeks and nothing has been helpfulso anyway heres what i got. I have a 93 240sx ka24de 5 speedjust bought the car drove it for 2 hours getting it back home get home and everytime i put my foot on the clutch rpms drop and the car stalls out, not to mention a huge lack in power since running on 3 cylinders since for whatever reason my injector isnt spraying so saturday i replaced the 4th injector, which i found out was that one by running the car and unplugging each injector til i found the one that didnt effect the idle when removed, and it ran fine for a while got to my friends house great, let it sit for a couple hours and then on the drive home huge lack in power, same misfire and stalling again at decelerationso far i've change spark plugs, wires, cap, rotor, injectors, fuel rail, new fuel lines and still nothing, the car has msd on it and timing is slightly off but i still cant figure out why the 4th injector isnt spraying, i tested all injectors with an ohm meter and got between 12-14 ohms on all 4 injectors, switched ecu's with a car that i know is good and came out of a running car, cleaned out intake manifold using seafoam checked for spark in all four wires and coil and everything tests good but im still getting a misfire in the 4th cylinderdoes anyone have any clue to why im still getting a misfire in 4th and how i can possibly fix it and why is it the car stalls out at deceleration, is it caused by the misfire or another problem on its own??thanks for any help at all
