Sygerwulf »
https://forums.nicoclub.com/sygerwulf-u1051.html
Tue Nov 12, 2002 11:51 am
hmm, when my friend and I put new injectors on his 3rd gen eclipse we had to tighten, then run, then tighten again, and run. You have gotton the bolt pressure on the front of the fuel rail slighly tighter then back, allowing the back injector to leak. Try tightening down the back bolt and running again and see where it leaks, and try and make sure you get equal pressure over the entire rail
