CharlieB »
https://forums.nicoclub.com/charlieb-u10442.html
Mon Oct 06, 2003 7:41 pm
Hi,
I have a 1989 240SX (California model). The computer keeps giving me an injector leak code (45). I have replaced the injectors twice, replaced the fuel filter and all flexible lines as well as the O2 sensor and spark plugs. The car runs great. The mileage is good. There are no indication of leaks at the injectors. I now suspect that the problem is in the sensing system. As there is no fuel pressure sensor, does anyone know what information the computer uses to determine that the injectors are "leaking?"
One final piece of information, the car was build right at the change over of injectors. There are two types of injectors you can buy. One is "orange dot" for all four cylinders and one is "blue/black dot" one color for 1/4 and the other for 2/3. The dealer could not tell me the correct injectors even with the VIN but said if all four are replaced it did not matter. Anyway I used "orange dot" and don't know if this could be part of the problem. Does anyone know the difference? Could the computer be matched to the color of the injectors?
I am out of ideas and injector sets are not cheap-- PLEASE HELP.
ThanksCharlie
