I put contact cleaner in the injectors and cleaned out the corrosion and original dielectric grease buildup and blew it all out with a keyboard duster, the contacts on the injectors are super clean. After i did that, the car will run great at startup for about 5-10 secs then go to missing. I've swapped his ECU into my car and my car runs fine with it so it's not ECU related.
I'm starting to think this is an injector related issue. I've checked the injectors I can get to.
1: 17.1 ohms
2: 12.5 ohms
3: 12.1 ohms (this one fouls plugs, suspect it's mechanically stuck)
4: 15.1 ohms
5: can't get to so didn't check. it's the STRONGEST cylinder and unplugging it will make the car die almost instantly.
6: 14.0 ohms
I also checked these readings behind the electrical crimp and solder work I did to put in the new connectors and all readings are within 0.0-0.1 ohms. I bought the connectors on ebay but they're like the ones Z1 sells.. actually I payed more since I didn't check Z1 first
Is it possible this car had 3 injectors just "go bad" overnight? The car ran fine before the work, ran decent the day I finished (ran rough at cold start but smoothed out after a short test drive) but the next day started all this mess. I'm wondering if driving the car with the connectors fixed and working maybe "overworked" the injectors that had been corroded for at least the past 5+ years.
Owner can't believe these injectors just "went bad overnight" and wants is "running the way it was before he brought it to me" so would it be bad to recommend he replace all the injectors? Or should I keep looking elsewhere?
