Injector installation gone wrong
kisakron
Car: 1994 q45
Hi I am new to this site and need some information from experienced mechanics.Recently my sons 1994 Q45 began running rough. I brought it home from his school, about a 40 mile drive. After combing this site I was able to find an open ohm reading on injector two. I ordered a beck arnley rebuilt injector. Initially it leaked from the top. I reseated the injector and it quit leaking from the top. However, it continued to run rough and began spewing blueish smoke from the exhaust. I ran it for about ten miles and it did not get better. I removed the injector and discovered that the lower o-ring was distorted, sort of smashed and ripped.I imagine I was dumping a lot of fuel into the cylinder.My questions are 1) could I have ruined the cylinder in the amount of miles I ran it with the gas washing through it and 2)how do you properly align the injector for installation?
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
kisakron wrote:Hi I am new to this site and need some information from experienced mechanics.
... welcome to NICO! Hope we can help. I'm hardly and experienced mechanic, but I relish the opportunity to offer up some basic opinions before the real experts get here.
Quote »Recently my sons 1994 Q45 began running rough. I brought it home from his school, about a 40 mile drive. After combing this site I was able to find an open ohm reading on injector two.[/quote]I'm just checking on this one... but, do you have the results of the ohm tests? I'm assuming you tested all 8... can you post up the readings you got from each. And, could you post up results from all 8 as they are today? This may help going forward.
Quote »I ordered a beck arnley rebuilt injector.[/quote]I think you are going to get mixed reviews on this decision. Seems like most of the experts recommend buying new OEM injectors upon injector failure. Personally, I have no problem with reconditioned... but, I need to know it is coming from a great source. I've had very good luck with Deatschwerks (NICO sponsor)
Quote »I removed the injector and discovered that the lower o-ring was distorted, sort of smashed and ripped.[/quote]This is, apparently, a very easy mistake to make. Lots of warnings from the experts regarding possible issues from incorrect installation. Personally, I avoided this issue with mine by sending the whole fuel rail to Deatschwerks and having them test, recondition, replace the injectors. They reinstalled them in the fuel rail for me, and sent it all back intact. This will help you avoid most of the installation issues.
Quote »I imagine I was dumping a lot of fuel into the cylinder.My questions are 1) could I have ruined the cylinder in the amount of miles I ran it with the gas washing through it[/quote]Could you have done damage? Yes. Flooding the cylinder could cause you to bend a rod... I think. I'll leave this answer, and some recommendations to find out whether any damage was done, to the experts.
Quote »and 2)how do you properly align the injector for installation?[/quote]Send it to Deatschwerks and have them do it for you!
kisakron
Car: 1994 q45
Thanks for the quick response.The number two injector read infinite ohms, just like when you have the test leads seperated on the digital multimeter. The rest of them and the new one read 11.5 ohms.
kisakron
Car: 1994 q45
Oh by the way I did contact Deatschwerks, but he said he did not have one in stock and he could not fix one with a bad coil.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
kisakron wrote: I ordered a beck arnley rebuilt injector. Initially it leaked from the top.
Rebuilt means used. Injectors are a wear item and should only be replaced with new OEM from http://www.infinitipartsusa.com
One should vary from OEM only when one knows for a certainty that the part will work as well as almost all 3rd party parts do not meet OEM standards.
Read and you will learn. Welcome to the knowledge warehouse for the Q45.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Hopefully the B/A injector will work for you. Good luck!
The key is just to lube it really good.... and you cant twist and push, you just push.
i dont think you've done any permanent damage, if you hydrolocked the car causing a bent rod your motor wouldnt run so if anything when the engine starts to age more you'll see less compression on that cylinder. Still, i wouldnt worry too much.
kisakron
Car: 1994 q45
Thank you for the encouragement Wes, it gave me the confidence to try again. I did as you said, push no twist, with plenty of grease on the o-rings and the miss is gone. I was lucky I had the old injectors o-ring to replace the one i ripped.Wes you again were right, there appears to be no major problem as a result of the fuel dump. My oil was pretty thin but it has been changed.Thanks againWes,I will be rooting for your Colts on Sunday.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
kisakron wrote:Thank you for the encouragement Wes, it gave me the confidence to try again. I did as you said, push no twist, with plenty of grease on the o-rings and the miss is gone. I was lucky I had the old injectors o-ring to replace the one i ripped.Wes you again were right, there appears to be no major problem as a result of the fuel dump. My oil was pretty thin but it has been changed.Thanks againWes,I will be rooting for your Colts on Sunday.
Well done!!
ponzy
Car: infiniti q45
nice kisakron.....hopefully i'll have my q rolling ASAP, i am going to send my rail with injectors on it to deatschwerks tomorrow so i'm looking by friday(feb 9) to have it back to me ........
