Not_a_sr »
https://forums.nicoclub.com/not-a-sr-u23501.html
Tue Oct 17, 2006 4:46 pm
Its a pain in the As*, i just did mine three fn times today...
un do the fuel lines, unclip the injectors,take off the bolt by the FPR, then undo the bolts on the intake manifold, pull apart wiggle out , install new injectors using oil on the seals, then install the same way, while you have it off, replace the hoses with new fuel injector hose from a parts store 5/16th line its about $6.50 a foot. once its all installed have someone prime the pump a few times while checking for leaks, once no leaks are seen have friend start car wile looking for leaks.
