-RJ- »
https://forums.nicoclub.com/rj-u45010.html
Tue Mar 16, 2010 1:07 pm
What are you trying to do exactly? If your just trying to replace one of yours then any KA motor will do. If you want bigger then 300zx turbo and 95-97 q45 will fit as well. These are 370cc, but if you use those, you will have to get a tune otherwise your car will be running really rich.
I have a set of 97 q45 injectors I'm going to use. Just make sure when you install injectors, you need new orings and you have to lube up the orings too when you put them in
