My question is... Does nissan use high or low impedance injectors.
If i am not mistaken even if they are high impedance then you could use resistors for my idea.
The Eclispe Turbos have 440cc injectors from the factory (once again if i am not mistaken) and you can get a set of 'em for nothing at the junk yard. I'm planning on buying my buddies s14 blacktop t28 as soon as he gets his swap in. (he is upgrading to some HK$ stuff before the swap)
I would like to have a little margin of safety with the turbo and 440s seem like the way to go till i get the funds to do things right.
Thanks for the help
OK let me edit:: what resistance are the sr20 injectors are are there only 2 kinds ie are all highs the same resistance and all lows the same...
