injector idea!!!
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
ok so i just got a genius injector idea.
http://cgi.ebay.com/ebaymotors..._1216 + http://www.frsport.com/Greddy-....html + http://cgi.ebay.com/ebaymotors..._1040
better than a stock rail and side feed injectors, for about 200 dollars less than 740cc injectors from nismo or hks. aren't bosch injectors a pretty well known trusted injector? any thoughts on this setup?
themadscientist
Bosch is one of the heavy hitters in EFI, have been since the beginning.
heartofaskyline
freakin sweet! im so stoked. i can do my whole fuel system, for about the cost of a simple set of side feeds.
future240owner
Car: 1992 240sx coupe SR20DET
Very curious let us know how it works out.
heartofaskyline
will do. i did the math, and with...'
bosch 72lb. injectors (aka 750cc) $110greddy rail (to match my IM ) $190sard FPR $136braided lines and 6AN fittings $30shipping and handling $9
total= $475 at my door
thats a much better setup than 740cc in a stock rail, and its cheaper
heartofaskyline
after alot of research, ive found that this can be done, but not quite like i had planned, jdm fuel rails do not work with msd/bosch style injectors. you will need a fuel rail from jwt. secondly, all msd/bosch style injectors run off a 2 ohm while sr20 injectors run off 11 ohm. you will need a resistor box out of a dsm/honda, or you can get individual resistors from jwt as well. all in all you can prob save 100 bucks with this setup and be topfeed. not a bad deal at all if you ask me.
i might do a full review on this as well as a detailed install if anyone requests it???
Gr8plainsDrifter
Car: 1989 240sx
also, when tuning with bosch inj. there is a longer delay time, ive read somewhere, than OEM, or others. So when tuning with whatever you got, take that into account.
Jadesr20det
Car: 1990 NISSAN 240SX
Im a skeptic by nature but will keep my eye on this.....there has to be a reason a lot of people dont go this route though
