Axel Grungy »
https://forums.nicoclub.com/axel-grungy-u8570.html
Mon Sep 27, 2004 5:01 pm
ok im pretty sure this is an injector problem. every once in awhile my car likes to run on three cylinders (IE motor shaking, sounds like harley) when i start it up. im getting spark on all cylinders cuz i pulled out the wires one by one.l ive narrowed it down to the #1 cylinder. btw i havent pulled out the spark plug yet to see if its fouled or not, but i would guess once its fouled it will not work at all. so im pretty much ruling out the spark plug as the prob, but i will check it tomorrow (new ngk's were put in under 1k ago). ive also checked around the injector to see if theres any gas leaking from the O ring and tahts negative. so my question is how do i make sure the injector is working?? btw ive cleaned the contacts on the injector plug also. but im pretty much stumped, this prob comes and goes.....any ideas would be appreciated.
