Q451990 wrote:I think I'd change the oil too! You may have gotten some gas down past the rings. Never hurts to go ahead and change it. Just out of curiosity, did you pull the pump fuse and let the car die before pulling the injector?
Heath
Haha. I've already told the girl to go have the oil changed for that very reason.I did pull the pump fuse just like usual. Start it, pull it, die. For whatever reason, the fuel rail was full this time. Stunk up the whole garage with fumes. I had to get a rag and soak up the fuel out of the line to make room for the injector. Weird, it worked fine last time.
Quote »Yikes! Hydrolocking! Man oh man. Mayhem, if you escaped from that unscathed then you have used up one of your lives. How is your engine running? Any changes from the norm? Lessons for us all. Hope all is well.[/quote]
Engine is running fine. Very smooth now. I'm guessing those two injectors I"ve recently replaced had a little to do with (before they completely died) my slightly rough idle. An idle most people would never notice unless you're picky car freaks like we are. Idle is glass smooth now.
