injector ground wire?
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
Ok puting in my emanage and it asks for a injector ground wire I cant find it in any of the wire diagrams so if someone knows which one it is it would be great if you could tell me. Thanks
virus77
Car: 95 S14, 71 240z, 97 e320
s13 or s14
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Injectors are controlled by the grounds. So to answer your question, there will be 4 injector grounds coming out of the ecu harness.
The injector 12v + are all joined, and the source leads from the fuse/relay box.
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
it is on a s13 sorry
deviousKA So all the wires that are going in to the maf are the grounds?
deviousKA
Maf has
ground12v+ feed0-5v reference back to ecu.
the ground wire should be black, 12v+ feed should be black with white stripe, 0-5v ref back to ecu should be white.
The black with white stripe 12v+ for the maf is the same feeding the 12v+ to the ecu.
