The problem occurs when an injector is replaced without knowing its flow rate or the flow rates of the remaining old worn injectors.
At idle a balanced flow rate is necessary for a smooth idle, so power balance test should be conducted and some determination as to whether any rpm imbalance is from injectors or piston ring wear [low compression].
New plugs, clean injectors [BG44k] and individual cylinder compression test looking for correlation.
By the way the fluids used to test injector flow may not match the viscosity/specific density of the pump gasoline you buy from day to day.
Note: 0.696@25C in the test sheet you must be prepared to measure your gasoline at 25C and correct the flow rate vs that given in test results.
Gasoline, Vehicle 60F 0.739 Toluene 25F 0.865 Alcohol, ethyl (ethanol) 25F 0.787
http://www.oseco.com/pages/abo...s.pdf
Unleaded street gasoline, regardless of the octane rating, should have a specific gravity of 0.720-0.780. As was established earlier, no two loads of fuel delivered to a gas station have the exact same density!
