Qdog »
https://forums.nicoclub.com/qdog-u384.html
Thu Jul 10, 2003 11:58 am
I'm finally going to pull the plenum for the first time this weekend (wish me luck). Suddenly, the car developed a miss. I will ohm test the injectors, but if this does not show a bad one, is there a way to determine if one is bad (short of consult) ? The idle is shaky, and there is much shaking under load especially below about 2200 rpm, and higher rpm power is down. I will be replacing plugs, cleaning everything. I want to be confident that the injectors are okay before replacing the plenum. I want to bench clean them, but unsure of the best procedure & cleaning solvent. Can I safely apply 12V to an injector for several seconds to allow solvent flow ? Or should I just take them to a shop that can clean & flow test ? TIA
