This comes from a old 300zxtt forum. It is an interesting concept that the constant +12 volts on injector causes corrosion [ethanol with water conducts a little.The Q constantly supplies +12 and the rail is grounded thus some current could flow? I will test today and report. Easy as there is an injector fuse
"Well, now I know why I keep eating so many fuel injectors. Apparently it's normal for Nismo 555 injectors to last only a year in the 1990 to 1994 300zx...
http://www.twinturbo.net/net/v...35571
Some more comments from Greg @ SpecialtyZ:
We have had many,many,many nismo 555 injectors fail in the last coupleyears and nismo will not do anything. some of the early style injectors are only lasting a couple months. Since the fuel changed with alcohol content they are all failing extremely soon.
I feel for you that your experiencing problems with nismo injectors andyou are far from alone.
What is happening to the injectors is that they are corroding theinternal connection and causing an open circuit. The injectors are not getting shorted coils from running past their duty cycle.
The early style injectors have positive 12 volts all the time. The fuelformula changed a few years ago and they started adding alcohol to thefuel. Since the time the fuel was changed the injector failures of cars withearly style injectors is through the roof, (brand new and original early styleinjectors we are replacing several a week). It is believed the alcoholand having power to the injectors is causing electrolysis and eating up theconnections internally causing the high failure rate. They are nothaving this problem in Japan and they make fuel the way we use to withoutalcohol. The injectors were originally designed for fuel that we do not have anymore.
The stock injectors use to last 10 years easy and we hardly ever hadfailures......Now we are having to replace stock injectors that havealready been changed in less then a year all the time as well as originalinjectors failing almost daily. The late style injectors are wired to the ECU differently and do not have power when the key is off.
By old style, I mean the 1990-1994 year style injectors.The new style injectors that were used in 1995 and newer Z cars arecompletely different in design and require different code in the ECU and donot have power going to them from the ECU until the key is turned on.They also require a different fuel rail to bolt them in.They are not directly interchangeable. It requires different fuel rails andmachining of the lower intake manifold to accept the newer style fuel rail.It also requires changing the injector electrical plugs and ECU chip.
You absolutely have older style injectors because that is all you can usewithout major modification and changing all the injectors to the late modelyear style.Your only option at this point is to replace the one bad injector unlessyour willing to go to the expense of replacing all of them and doing themodifications to change over to the complete new set up.
Nismo is aware of the problem now and we have a lot of documentation.We are hoping nismo comes up with a solution for direct replacements.
I am recommending to people doing upgrades currently to change over to thenew style now they we know there is a problem with the old style injectorscombined with our current pump fuels.For years the Nismo 555cc injectors were a great relieable injector.
Other company's selling injectors for the early application are assembledthe same way and the ECU program for the early style injectors has the ECUsending power to the injector all the time adding to the electrolysisproblem.
Mike Smith and JWT are looking into ways to help the injectors live longerby wiring the injectors differently. This is still in the testing stages andwe are hoping to offer at least a patch of some kind to help with peoplethat have these injectors.
I feel your frustration, I had to change 3 of the 6 injectors in less then ayear on my personal 300ZX that had the HKS 2530 turbos......I replaced themall with the newer style 740's and fuel rails when I put JWT 700 turbos inthis last year.I still have all my 555cc Injectors in my 280z that has the twin turbomotor and Greddy TD05 turbos. I did wire this car myself when I did theengine conversion and I do not have power to my injectors when the car isoff.This just happened by accident because I wired the car and the fuelinjection relay does not have power until the key is turned on.
