colincliff2 »
https://forums.nicoclub.com/colincliff2-u54836.html
Sat Sep 25, 2010 6:20 pm
Thanks swimshark, I replaced #5 and it was actually pretty easy. The Dremel method is definitely the way to go. For anyone else who needs to do this, here are some things I encountered:
-The rubber fuel hoses would not come off the hard lines, so I had slit them with a knife to get them off. They were old & brittle so it was a good opportunity to replace them.
-I unbolted the hard lines that run across the top of the plenum and held them off to the side with bungee cords. This cannot be done with the lower line (the gold one), but you can use a screwdriver to slightly pry it away from the work area.
-Soak the two injector screws in WD40 for at least 24 hours. Spray them with brake cleaner just before removal to get rid of the slippery WD40. I also set a #2 philips screwdriver into each screw head and hit it firmly with a hammer in hopes of getting the screwdriver to sit tight in the screw head. I was able to remove both without stripping them.
-I ended up using a 14mm deep socket, extension, and a mallet to press the new injector in to the rail. I just positioned the socket right on top of the injector (the flat, round area - not the connector.
-The injector connector is kind of tricky to put back on because you have to press down REALLY hard to get it to latch. Once again, a hammer and a screwdriver helped to press it down tightly.
I probably saved close to $700 doing this instead of taking it to a shop.
