Injector "F27" Plug Location Question
ThatOneGuy
Car: '95 240SX SE with SR20DET
This might be a weird question but my car won't start and I think it's because the injectors aren't firing. I've got an S13 motor but I'm trying to diagnose with the Zenki S14 manual. It says to check power, continuity and what not at the F27 meets F111 plug but I can't find those plugs.
I followed the cable running away from the injectors and found a couple of plugs but they each have 6 wires instead of the 8 wires that the FSM says to look for. I guess my question is two fold. First, is it still the 8 wire plug for the S13 motor? Second, if it is an 8 wire, any hints of where it might be found?
I used the u-turn behind the motor method of running the wiring harness if that helps at all. Thanks.
