Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu May 25, 2006 6:56 am
Idle is usually the problem with larger injectors and with reduced psi to 34, the injector gets derated 34/43.4= 0.7834 then square root = 0.885 or 11.5%.You cannot use a lower than 34 psi pressure and many times the idling opening time is the minimum, so with larger injectors you must live with too rich [plug fouling] or a much much higher idle speed.
