I stand corrected, I got the year when they changed mixed upZ31toZ32 wrote:^ i believe 90-94 TT and 90-93 NA injectors were all the same so it should be fine with new o rings.
If you're swapping injectors within those years you're good, if you go NA94+ or TT95+ then you need newer style lower plenum or adapter kit. if you are doing a TT swap then yes you need a TT or Walbro Fuel Pump.Z31toZ32 wrote:^ 90-94 TT and 90-93 NA injectors were all the same
