itsa300zx »
https://forums.nicoclub.com/itsa300zx-u135155.html
Sat Jun 27, 2020 10:22 am
Most likely corrosion in the connectors, very common for these 25+ year old cars. Try cleaning the contacts, if the connectors don’t crumble when you disconnect them. Biggest challenge will be removing the metal “U”clips that hold the connectors in place without damage to the plastic. I refer those clips as “b****” clips.
I’d suggest sourcing 6 new connectors with pig tails and replace old ones. Look locally for help if possible, the internet can only help so much.
You don’t need to be a mechanic to fix BUT do need a bit of patience, skill to work on these cars.
Also look at the connectors for the PTU and clean as needed.
Hope that helps.
