DougQ45 »
https://forums.nicoclub.com/dougq45-u513.html
Fri Mar 14, 2003 4:07 pm
Had 2 injectors out of spec (17 ohms, and 240 ohms) on my 1990 when it triggered the check engine light.
Embarassed to admit but 3 weeks ago I bought 7 injectors from a 1995 Q45 on Ebay from someone who said the 1995 will work in the 1990. The newly bought injectors were cleaned/reconditioned and checked by a local injector guy who found: i) resistance for all 7 was uniform at 12.8 ohms, ii) the pintle spray is a single hole, and iii) the spray pattern is cone shaped.
After re-conditiong/cleaning they all spray a nice cone shaped pattern (@35PSI) within 2% volume of each other. They were roughly 22% out of balance before. The injector guy swears they can be used in the 1990 as the fuel flow is identical, electronics are good, and the physical qualities of the injectors are identical. They are tan, whereas the old injectors were green.
Since I have the plenum off, and don't want to do this again, can the tan ones that are supposedly from the 95Q be installed into a 90Q?? All green ones can be pulled therefore replacement will be uniform/albeit different.
If not, I can just go to the boneyard a a find 2 green ones, in which case will shortly be selling 7 tan injectors on the parts board!! Help Dennis if you are reading. A good mocking is probably in order too for buying something that may not work as represented.
