scarboroughdub »
Thu Jan 04, 2007 3:55 am
you dont actually need collars if you can find same inside diameter injectors seals and larger outside diameter.
the reason for this is that the tx7 injector is narrower.
you can use the stock injector caps from the nissan injectors all you have to do is remove the little rubber piece inside.
what i did since i could not find larger injector seals is i had my machine shop make me some inserts that i jb welded into place, basically what these do is maintain the same outside diamter as the rail so they sit snug inside the rail but the since diameter is a tad smaller than the rx7 stock injector seals.
