Injector cleaner bad?
Found this on ConsumerGuide when reading about the 300ZX:
"Fuel pump: Adding fuel-injector cleaner to the gas tank can cause corrosion on the fuel injector coils, which will eventually damage them. (1990-94)"
Could this also be true for early Qs too? Or any car?
Raxephon
Car: '04 RX8...for the moment...
This would probably be a good question to throw at DeatschWerks.
I don't think adding injector cleaner to the fuel every now and then would warrant enough concern for me to care too much.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Remember that BG44k is the only injector cleaner approved by the factory, i have the TSB somewhere.....
Q45tech
The el cheapo cleaners and some expensive ones contain methanol which is the culprit...[in injector/pump/aluminum corrosion]..........many expensive ones: BG 44k, Techron contain a strong concentration of a detergent approved by EPA for gasoline which doubles or quadruples the concentration of the same thing in the fuel.........in a xylene/tolune solution......1-2-3 ounces of active detergent in up to 8-10m ounces of gasoline like material to pour in and dilute.
Fuels could be made detergent rich for a few more pennies per gallon at the refinery instead of forcing us to pay a 75 cents-DOLLAR per gallon for the same concentrate.
I can assure you BG44k won't affect 1990 injectors having used over 80 cans in the last 15 years and 303,000 miles still as built oem injectors and o rings [they were removed once and cleaned externally].
Bad fuel purchased causes injector problems, along with avaiable to public methanol based cleaners.
Easy to look up chemical contents [code numbers-CAS [not college alcohol society]: Chemical Abstracts Service] on web.
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
Where Can we get this stuff BK44 (by the case)?
Joe?
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
http://www.bgfindashop.com - you can find local shops that perform BG services and will most likely carry their products.
http://www.ebay.com - careful of shipping prices...
or,
http://www.froogle.com - at least one place that will sell it by the 1/2 case for about $160.
