Injector #4 and fuel pump help
unknown007
Car: White 1993 Q45 (G50)
Them all ohm at 12.8 and 13 but number 4 ohms at 16.6 which i should replace right?I also did another test with the injectors it's like cranking start or something?Well i did it with my teacher and we disconnected the Fuel Pump fuse.For some reason the gas wont drop much now.Any idea?
Unnatural1
Car: 1994 Infiniti Q45
I'm not sure I understood most of that. But the #4 injector sounds like it's on it's way out. You may not even notice it yet. It may work for a little while longer but it's going to get worse. A replacement would be a good idea in the near future.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ummmmm....might be best to ask the instructor to write a note for you then post that note verbatim.
unknown007
Ok let me re-explain everything.
My #4 injector as Unnatural1 stated I guess is going out.Any price range for all or just one?
We did some type of test on the injectors.All we needed was to have it crank but not start.So what we did was take the fuel pump fuse off.Cranked it did the test done.I put it back in but now the Fuel gauge wont move down.
Any idea or is it just me?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Did you check and see that the fuse gets power?
I have ONE brand new injector if you interested, did you try that BG power flush of the injectors?
unknown007
ppastos wrote:Did you check and see that the fuse gets power?
I dunno how much for the injector though?The fuse does get power Ima drive right now so i'll update on the fuse.
Maneater
Car: 1990 G50
I may be interested in that injector. is it an OE one?
Q451990
I don't think the fuel gauge is related to pulling the pump fuse... How far have you driven since you ran this test?
Heath
unknown007
Never mind it works now!!!
ppastos let me know about the new injector with a price maybe email me or something.I maybe need it soon before it goes out.
