help
injectors will not work. there is fuel getting to them and they are getting the voltage the need from the ecu but when i crank the engine nothing, i checked all relays and the work fine, tested the injectors and they work fine too. might it be because i switched to a j4 ecu as apposed to the e5 ecu. i mean is there something more to chande then just the pins for the igniters
any help would be great
