InjectedPerformance »
https://forums.nicoclub.com/injectedperformance-u22434.html
Fri May 19, 2006 11:28 am
FRONT VIEW
REAR VIEW
Introducing the S5 5 lug conversion hub for Nissan 240SX S13 89-94. Super lightweight & strong material for better traction and quicker acceleration. Perfect for those street drifters on a budget and tough enough for even the pro drivers expectations. Mild steel construction, utilizes OEM bearing with OE length wheel studs. All components machined for perfect fit and optimum performance. Installation is a snap, making even the novice mechanic install with ease. Whether you are trying to expand your wheel options, drag racing or drifting is your thing, stop wasting your time with those other kits or trying to modify factory parts, install your S5 5 lug kit now!
Front Hub:
OEM bearing & lightweight designed Standard Wheel Studs Mounted Stage 3 entirely designed in-house bearing Compatible with all kinds slotted rotors & spacers Rear Hub:
Nissan Factory Hub OEM Hub Bearing Inserted CNC Machined for precision and accuracy Standard Hub Studs Mounted Easy Installation - Plug & Play MSRP IS $600
NICO PRICE- $499 Shipped!
