encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Sat Aug 14, 2004 8:21 pm
Thanks alot again. I reset the timing using your method today and it turned out to be wayy off, I lined up everything at TDC compression (I think before it was aligned at TDC exhaust) and the cams were already aligned.
Anyways, after doing this, the car started up on the very first try, and apparently, this is the first time the car has run well in a very long time, as I just bought it in non-running ocndition on Friday.
Also, I noticed on Heavy Throttle's website that they say that TDC is the second notch from the RIGHT, but your info is synonymous with the FSM and worked for me.
Again, thanks a ton.
