NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Apr 20, 2005 1:30 am
I should add also that if your state checks SRT moniters as part of the emissions inspection,you are going to need to drive the car till it conducts most or all of those tests. What they are is Self Readiness Tests. Meaning the car checks all of its functions of emissions copmonents. on your car you should have 5 visable tests that can be seen on consult and 3 non visable that generic scan tools can see, the 3 you dont need to be concerned with cause they run imediatly upon starting and driving the car, the other 5 are time tests that require specific conditions to be met for the tests to run. They 5 are EGR,O2,O2heater,EVAP,and Catalyst. The first 3 happen pretty quickly the Cat test no much longer, The evap test takes a bit of driving for it to complete since it tests multiply functions of the EVAP system. I believe under perfect conditions its around 17 mins.
