juiceman »
https://forums.nicoclub.com/juiceman-u145.html
Fri Mar 14, 2003 8:11 am
I guess what tech says is correct. but if you want to work on your own
There is a way to do a high pot test. It measures the voltage the unit is supposed to hold voltage insulation to. I wonder if there is a way to know the requirements of this for this transformer. And better yet a place to do the high pot test. Used to have access to one but that company has moved some years back.
One solution without going to the extent of the above is to buy a new coil pack and install it in one loation and see if that solves the problem. If not, them move to the next cylinder and so on and so on till you find the correct cylinder.
Changing the coil packs is very simple. I think it is a 12mm socket to remove the two bolts holing the coil pack down. Unclip the connector and slde it out.
I would first buy a multimeter, will always be useful, and ohm out the wires as stated in the manual.
Good luck
