generic808 wrote:If after disconnecting the battery and the lights don't turn off, just drive it for 50-100 miles and most times the comp will adjust itself.
Hey All,
The battery disconnect did the trick. Thanks to all for the help. I encountered the Auto-Up window issue, and reset according to the instrucions on the other thread. All looks to be back to normal.
On a related note, I was talking to a buddy, who has been a long-time modder of Mustangs. When I asked him his thoughts on this subject he ask me if I had disconnected the battery also. But, not for the safety factor, rather for the ECM reset factor. That triggered my memory about the other discussion on to disconnect or not during install.
My buddy's point was that afer installing anything that has an air, exhaust or such sensor, the disconnect of the battery resets the ECM (Just like this light issue) and you're back to ground zero on the ECM adjusting itself to reflect the changes.
Not sure if the A/C works the same way, but it sort of gave me an inkling that the suggestion from INJEN to disconnect may not be all safety oriented.
Hope this helps, -- Wind
