Booo just get a real motorNismochick240 wrote:I found some really good info on weight reduction... i saw that some people had asked out stock weight and about reduction so here's a lil info i found for all yall niconauts!!
Nissan 240SX Stock Weight - 2859lbs Stock Wheel Weight - 22lbs each/without tires The Nissan 240SX's weigh approximately 2859lbs, depending on the model, with a max difference of roughly 100 pounds from heaviest model to lightest. Dividing by the horsepower of 155, we get about 18.4lbs/hp. So roughly every 18.4 lbs removed from the cars weight will add an effective 1 hp. Gas weighs about 8lbs/gal so 16 gallons in the tank weighs 128lbs. If you have only 1 gallon in the tank, its almost a 7 horsepower equivalent difference. A passenger can make even a bigger difference, not to mention the drivers weight. You can easily remove things like the spare tire and jack, the floor mats, the rear seats, interior panels and anything else.
Listed below are some easily removable items: 1. Passenger Seat (37lbs) - Removing the passenger seat is a very easy and effective way to give your 240SX a small gain in power. The nice thing is that the seat is only held in place by 4 bolts.
2. Rear Seat (29lbs) - The rear seat is a little more complicated to remove than the passenger seat. When removing just remember where everything goes and it should be easy to put back in place whenever needed.
3. Rear Seat Cushion (10lbs) - The rear cushion should be removed at the same time as the rear seat.
4. Floor Mats/Front and Rear (6lbs) - This has to be the easiest weight reduction available for the 240SX owner.
5. Tire Floor Cover (3lbs) - The tire floor cover is right underneath the rear hatch carpeting.
6. Spare Tire and Jack (32lbs) - Another easily removable item.
Total Easy Weight Removal = 117lbs or about a 6.3hp increase. Intermediate Skill Weight Reductions
The weight reductions included below can even prove more effective than some of the reductions included above. However, once you start removing these items you are taking away from the cars overall appearance and in some cases its more predominent ammenities.
7. Air Conditioning (40lbs) - Removing the air conditioning will net you a reduction of about 40lbs. Be sure to remove everything from the engine as well as behind the dash. Should be completed by the experienced only.
8. Front Hood (50lbs) - Replacing the Front Hood with a lightweight fiberglass or carbon fiber hood is a great way to remove some weight around the front end of the car. Total weight reduction will be close to 50lbs or greater depending on the aftermarket hood you choose.. If you dont intend on replacing the entire front hood you could also remove the sound dampener on the inside of the hood. This should help in cooling your engine a little.
9. Stock Wheels (22lbs each/replacement weight from 11lbs each) - Replacing the wheels is a must for anyone seriously interested in increasing their cars performance. The stock wheels are quite heavy and can be replaced with a variety of aftermarket models. We would suggest searching for lightweight wheels. Replacing your wheels with lightweight wheels will dramatically increase your cars acceleration. We suggest not going over 17 inches if maximum performance is what you desire to achieve.
10. Front Drivers Seat (40lbs/replacement weight from 14lbs) - The front drivers seat on the 240SX can easily be replaced with a much lighter alternative A lightweight racing seat will save you considerable weight and will also be effective once you have added more horsepower to your car.
Total Intermediate Weight Removal = up to 188lbs or a 10+hp increase. More Weight Reduction Some of the things listed below can also be removed or replaced with lighter alternatives than stock. Stock Flywheel - Can be replaced with lightweight aluminum flywheels or machined down in excess of just 13lbs.
Stock Steering Wheel - Can be replaced with lighter performance steering wheel with no airbag.
Passenger Airbag Removal - Can save some extra weight as well. (Not recommended for normal driving)
Interior Panels - Both the drivers side and passenger side front door panels as well as the rear panels can be removed to save in excess of over 40lbs.
Stock Speakers - With a weight of over 2 pounds a piece these can also be easily removed.
Rear Hatch Cover - This can simply be removed whenever needed. Weight is close to 6 lbs.
Replace Stock Exhaust - The stock 240SX exhaust weighs considerably more than some of the aluminum aftermarket exhausts. We suggest going with the Stillen or Borla cat-back exhaust.
Wiper Motors - Although they are generally needed under almost all driving conditions they CAN be removed if need be although we do not personally recommend it.
Carpet - Removing the carpet as well as the carpet lining underneath will reduce the cars overall weight by close to 40lbs. Removing excess wiring and bolts and brackets will also net you a reduction of close to 10lbs.
(p.s-> make this a sticky!! haha)
Ah, I just read where you said it was mainly for race/track. Gotcha.0wn3r wrote:read the thread
[edit: no, not really worth it]
Yeah, thats the problem. Someone broke into my car about a month ago, and stole my cd player.Nismochick240 wrote:sky- its not bad to gut ur car... i gutted mine from the seats back... sounds like the exhaust is louder but no big deal! lol! you dont hear a lot of road noise if ya have a radio!! lol
Yes that is a more detailed list. Guys I know are doing this project and I'm helping out occasionally, think I'm on there a couple times. But good project and great documention.lee. wrote:Time to pwn.http://www.mysportscar.com/fea...x.htm
Here's the build up of the car.http://www.mysportscar.com/features/project240/
That right there is the only problem I have....no radio...although I might still do it anyway just because I dont have any money, so Im looking for stuf to do. lolDjPantsSpecR wrote:...Road noise is almost negligable, but it does take a lot of radio on the highway to even sound at the right volume
Thats all I read. I hate you.Doomed2Walk wrote:MY05 STi
lol...I think Im gonna go for it. Gotta wait a bit until it warms up (if it warms back up) before I attempt it though.DjPantsSpecR wrote:ha neejay, you can just pretend you're ultra badass and gut the speakers too.... then brag about how hardcore you are. don't even put the passenger seat back in. no im just kiddin, no one gets the ladies without the passenger seat, and gutted coupes dont get ladies anyways, and who am i kidding i just plain dont get the ladies anyways...
anyways, i was just kiddin, you can notice literally no difference with the passenger seat in or out. However, it is close to an equivalent of about 2 horse, but thats crank horse, and come on now, you cant notice that.
the point i'm trying to make here, is that it makes your driving experience so much better. I daily drive mine everyday, and in stop and go, and i never want that interior back. You feel much more in touch with the car, and you hear problems and rattles that you wouldn't otherwise here in some situations.
do it, and get rid of that sound deadoning too.... but use a heat gun
HEY I own a Lexus and I am by fair no wuss... in fact the Lexus has Magnaflow's on herDjPantsSpecR wrote:If you're an enormous wuss that thinks exhausts are too loud or whatever, then by all means by a lexus.
you must own 2 S13's... because I was looking at both S14's and SC300/SC400's cuz they both look similar IMO. keep in mind that i think all SC300's were auto...DjPantsSpecR wrote:ha sorry guy, don't take that the wrong way. i cant wait to get my hands on a sc300, i'd trade both 240s for that any day... but then of course id have to strip the crap outta it
however, what i was trying to note is that it makes your 240 sound and feel like the pile of crap it probably is, and not the lexus you roll to your business meetings, all mushy and cushy and other words that dont rhyme
plus no more weight in the rear, so open diff just got that much less fun...
and you know i'm not talking about your mint *** 98 either, i hate you...
Nah, it would just be from behind the front seats to the rear. But to be honest, my car's interior isnt the best thing to look at anyway. And I'd take all the extra hp I could get with the condition my engine's in. And at least I'd be forced to keep the car clean without rear seats (I just throw stuff in the back seats and forget about it)0wn3r wrote:as for neejay, would you prefer a few hp and sacrifice all of the looks in your interior? you could probably do half and half... correct me if i'm wrong, but there's usually sound-deadener under the seat, get some of that out... or if you take the seats and everything completely out, you could plexi-glass a nice shell to fit inside (no offense, but i don't see you doing the latter..nicely at least)
You can't cancel out the units, it's lbs/ft-lb. And yeah, free 10ft-lb of torque at the wheels is nice. The only reason I am not stripping my car to the bare minimum is that I would like to start racing in the stock autocross classes next summer and weight reduction is not allowed in the stock class.DjPantsSpecR wrote:21.48 lbs/ per ft/lb (i dont know how to make the units work out, cuz that is in feet)
