Young_240_Guht »
https://forums.nicoclub.com/young-240-guht-u43522.html
Fri Mar 14, 2008 4:39 am
I thought you were going to say all you found in the search is *(parts for sale which sounds likely*
I'm pretty sure you use the RB MM from a R33, then the crossmember from a Gts-t. THat should put the engine low enough and in the right spot. This is from research... but you can hardly ever believe what any one person says, because someone else will say different. Best thing to do, is have a back up, and dive in dude take out old, drop in new for test fitment, get your driveshaft made, and maybe run some sort of standalone
Good luck
