damn my speeling suckmixeds14 wrote:so i shouldnt upgrade the rear only the front i do have a four lug but i would like to convert it to a 5 lug n since im going to the juck yark i see waht i can find any other car i could use to upgrade i apreciate the help thanks
No. Bad idea.KA24Power wrote:if you dont' want to convert to 5 lug, 94 altima front rotors work too. they're a bit thinner, but already 4 bolt.
its not about pad wear... its about brake clamping power/onset of said power. if your rotors are the CORRECT width for your Q, your brakes will engage sooner and without the slop of a few MM on each side... and since they engage sooner, they require less fluid to actuate them, resulting in less pedal travel required, giving your brakes the sporty feel/performance you are supposed to have. they wont behave like a hodgepodge frankenstein setup that wont keep the calipers and rotors aligned properly.KA24Power wrote:the pistons will never over-extend their intended reach, and the rotors don't wear out THAT much faster.
He's right, if you think about it, when you change out an old rotor and pads that have nothing left to each of them, they're still rubbing constantly, even though they're much smaller than they started out to be.KA24Power wrote:actually, they will work fine with no extra pedal movement. when the piston pushes against the disc, it stays there. there is no returning spring to pull it all the way back into the caliper. so effectively when you hit the pedal, the piston moves about 2mm MAX to push the pad back up against the rotor.
The rotor isn't a "hodgepodge frankenstein" setup. the caliper is bolted to the knuckle, and the rotor is bolted to the hub. the only movement is in the caliper bracket sliders, and guess what? those only move when the brakes are applied.
go look at your brakes after pushing the pedal, or better yet go to a brake job. you will realize that until you push back the piston (which isn't easy, its forcing brake fluid back into the master cylinder) the new pads won't fit on the new rotor.
If you're gonna try to tell me I'm wrong, make sure you're right.
