Djpants wanted to know more so I've decided to post it to everyone on the forum.
I will say that you should look inside you ecu to see if you have a 28dip(reads 27c256)(dual inline pin) eprom that makes it so much easier. For those without the 28dip eproms you must buy a daughterboard and two chips instead of on and a dip socket or zif, along with the burner of your choice. Or IIRC you can do a step down to sohc ecu. I could be wrong on that. You will also need to get a freeware or buy a rom editor that you are comfortable with. I like romeditor but will use tunerpro for some adjustments.
I will only run through the ka24e as it its simple just get a burner,zif or dip socket,chips(sst27sf512 or at29c256),and romeditor. Then get an adr file for your ecu s13,u12,d21 from
http://www.hybridka.com and load that to the romeditor and load a .bin file for your vehicle from above link or read your chip you remove from stock ecu and use that, now tune.
Okay on tho the de motor. You will need a daughterboard,2 above mentioned chips,burner,some sort of editor,.ecu file from
http://www.hybridka.com, or your ecu and a .bin file from ecu or the link.
Now it gets kinda tricky, the page will look like a bunch of damn numbers in boxes. Most outside left row is the address in a single row from top to bottom. Across the top in a single row is the TP load.Across the far right side is the rpm range. You take the tp load which is kinda like throttle position and cross reference that with the rpm. I will not give any math equations just know up is more fuel/timing and down is less. I will post a few links that can go more into detail for those who want to know more. I am not the first or last person to tune an ecu themself, trust me you can blow your motor if you do too much at one time. Start with your fuel and then move onto timing. Also GET A WIDEBAND o2 SENSOR/GAUGE before you go dumping a ton of fuel into your motor or worse going super lean to save gas. Get the o2 installed then play all you want.
this one is a write up for the dauhterboard install
http://www.sr20forum.com/showthread.php?t=94997 this shows the spot that will recieve the daughterboard
http://eccs.hybridka.com/viewtopic.php?t=161and the one for e engine people that goes into good detail
http://eccs.hybridka.com/viewtopic.php?t=149this is one of the most detailed write ups ever its for the 300zx but applies to the ka24e directly as well as the de as far as the tuning goes
http://cherrypicker.tripod.com/id10.html PLEASE NOTE! I am not responsible for what you do to your car. If you make a **** tune and your motor pops in front of you its on you. A wideband will let you know as soon as you get lean and you can stop right away. No a/f ratio monitoring no ecu tuning! Good luck
