The first part is written assuming you're asking how a torque converter works, and not just what stall speed means. If you already know, ignore this first part, and skip to the end.
A torque converter is the automatic transmission's answer to the clutch. Since an auto transmission is always connected to the engine while driving (even between gears during shifts), no direct mechanical connection would work--the engine would stall at stops or low speeds, and shifting gears would be problematic at best. With a clutch, the mechanical connection can be disengaged. With a torque converter, a compromise is made: a fluid connection replaces the solid connection, allowing the engine to rotate with the transmission at a stop.This is accomplished by having a thick oil that is rotated from the engine side by a turbine. The transmission side turbine is then driven by the rotation of the fluids. Think of pointing one fan at another fan and turning the first on--the second fan will spin as well. The performance and torque increases mentioned in the post above this come from the fact that the blades of each turbine can have different pitch values. This means you can effectively change the rotational ratio between the engine and the transmission. In this way, an artificial "step down" can be introduced before the transmission, further enhancing the torque that reaches the wheels, especially at lower RPMs (hence the reference to a good T.C. helping launches in the post above this one).
At higher speeds, both "sides" of the T.C. match speed more closely. And at freeway speeds, most Torque Converters have a solid physical connection that locks in, thereby circumventing the additional parasitic power losses caused by the inefficient fluid connection--this is partly why freeway speeds net much better fuel milage than normal city driving would.
The requisite "How Stuff Works" article.
zinkie13 wrote:....And what does changing your stall converter speed accomplish, since I hear about people doing it every once in awhile.
Basically:
Torque converter stall speed is the rotational speed (in RPMs, measured from the engine side) at which the torque converter begins transmitting power from the engine to the wheels. Below stall speed, the engine can turn without turning the wheels. Once the engine RPMs reach the stall speed, power beings being transmitted normally. Higher stall speeds allow higher RPM launches--it's a similar effect to revving a manual transmission higher before engaging the clutch.
Modified by MinisterofDOOM at 1:09 AM 12/22/2005
