mattback wrote:OH god where to begin. First let me say this.
With the proper tuning, the limits of the red top are VERY VERY high. Two very good friends of mine , Glenn and Scott, are both well over 370 WHEEL horsepower for months now, and have not had problems with anything but driveline parts. These numbers are done on t3/t04e turbochargers at approximately 20 pounds of boost.
I don't think that anybody was arguing that. I can tune a stock internal motor to last a few months at 400 HP. I think *years* was more of the thought for reliability goes.
Quote »Soggy boost response is because of poor exhaust wheel chocies and too large of an A/R On the exhaust housing. For almost all SR's and 8.5:1 compression, there is almost no need to run anything larger than a .70 A/R. The .63 t3 exhaust housing is ideal for any SR20DET that has any sort of redline below 7800 RPM. There is just not enough flow to merit the .82 A/R housing. You guys can disagree with me, but I have dyno graphs to back this statement up.
JWT is the one way to make less than ideal power on an sr.. they tune much too conservatively. You will see better power gains on just a Z32 maf, AFC, and 555cc injectors! [/quote]
The idea behind a JWT is not to make the ultimate power. They admittingly tune conservatively. That is why cars with JWT ECU's tend to last longer. Sure you can make more power with an AFC, but you also have to tune it yourself. A JWT ECU is plug and play, no guess work involved. If you don't know how to tune a car, a JWT ECU is a good choice for fuel management. Also, this way you build in a safety factor. If you tune it yourself, you tend to tune it to the limits, which is not good in the long run. Unless ofcourse, you spend hours upon hours on a dyno and tweaking the fuel map with a full management system, NOT an AFC.
Quote »As far as you saying it will greatly decrease the lifespan of your motor, by running these power levels, let me say that Scott's been running his car at 360+ wheel hosrepower every time he drives it (3 to 4 times a week) for the past 5 months. Scott and Glenn (400whp stock bottom end) both are on stock head gaskets you guys.. See what good tuning time invested can do ![/quote]
Like I said before... I don't consider "5 months" a long time. We want to build motors that last for years, not months. With that kind of lifespan, a larger safety margin must be implemented.
Quote »Why don't you guys catch me on aim if you want to make some real power. It seems dauntless obviously knows how to make the power, since he doesn't spend 20 hours a week helping out at a dyno shop, doenst have a swap in his own car, and only puts down 120 to the wheels if he's lucky. anybody can sell parts, i help realize their power. [/quote]
Um....so what if his car doesn't put down huge power right now....it's under development! If I pull the motor out of my car to build it, are you going to tell me I'm stupid because my car doesn't make any power?
Also, big deal you work 20 hrs a week at a dyno shop. Daunttless is opening his OWN dyno shop. Doesn't that tell you something?? And I don't know who the line about selling parts was supposed to be aimed at, but it better not be Daunttless. Because Afterdark will be primarily doing work on cars, making power, NOT selling parts. Apparently you haven't checked out the website. Because if you have, you would realize that it's not just a parts store.
