homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Sat Feb 12, 2011 11:12 am
?? Wait, what exactly are you asking, bc your last sentence doesn't make sense? If you want to know what the best rear-end gear ratio would be to run with the trans that's better determined by your motor, how it's setup (assuming you have the option to get a custom ratio), what your goals/usage for the car will be, and for racing, each track. Look at the S15's gear ratios, your rear-end ratio, and your engine's powerband and RPM range. You can also take into account tire diameter if you're running a much smaller or larger size (say for drag racing). There's a start.
