enjoyswf »
https://forums.nicoclub.com/enjoyswf-u216292.html
Wed May 01, 2013 3:58 pm
Thanks for the reply. I think you are correct. I decided to just get the OEM lugs. You did not happen to check and see what a new one of them cost? If not, you should be sitting down when you call Infinity parts. Fortunately, I found a used OEM set at a reasonable price. The quality of the nuts are excellent. The finish matches the wheels. The Infinity wheels that I got are also excellent.
The one interesting question that remains, has to do with how that wheel is centered using those shank-style nuts. I will find out once I get a new set of tires mounted. I will install them myself and get a good look at all of the contact points.
Thanks again for the reply.
BMc
