infinity service records
captainluigi
Car: 1996 q45t
new member here so help me along if you can. hope to pick up my 1st Q45t this wknd. its a ''96'' allededly serviced by infinity of pompano its entire life. heres the problem; service records say 98k mi., owner says 98k mi. but carfax & nada autocheck report odo. discrepancency. owner says it is a DMV clerical error. i want to trust but confirm. will infinity service depts. readily give this info out? any member suggestions will be greatly appreaciated. i have learned alot already by reading previous posts, but have not seen this prob before. awaiting anxiously, thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Welcome the best source for information on Infiniti in the world.
Getting them from the dealer depends on your relationship with a service writer. You should have a good one, because at some point, the dealer is the best alternative. The owner should provide you with a copy, perhaps by accompanying you there and requesting a printout from his usual service writer, thus introducing you to him? Having the senior tech (one trained on the G50 at introduction in 1989) inspect the car would be good and a heads up for you on over all condition and upcoming expenses for deferred maintenance.
No more y in Infiniti, please.
Modified by maxnix at 12:20 PM 11/3/2005
captainluigi
Car: 1996 q45t
thanx for your prompt response brian. also thanx for infiniti spell correction. anyone else have an opinion on the odometer discrepancy? sugesstions on dealing with DMV for correction of clerical error if that is the situation? this''error'' occured in 2000. thanks again, am looking forward to my switch from MBZ to INFINITI!
Chansen
Car: Q45
Good luck getting to the bottom of this.They should be pretty helpful at the dealer with the records atleast,check out the DMV also.the Q is a great car as long as you keep her well with her maintance
