code08red »
https://forums.nicoclub.com/code08red-u100911.html
Mon Aug 11, 2008 8:29 am
Will this amp have enough power for the infinity's
SpecsCEA-2006 Compliant Amplifier Power Standard:60 Watts x 4 @ 4 ohms <= 1% THD+N150 Watts x 2 @ 4 ohms BRIDGE <=1% THD+N80 dBA Signal-to-Noise RatioPeak Music Power: 120W x 4 (4 ohm) / 300W x 2 (Bridge 4 ohm)4 ChannelsContinuous Power @ 4 Ohm: 60W x 4Continuous Power @ 2 Ohm: 75W x 4Continuous Power Bridged @ 4 Ohm: 150W x 2Frequency Response: 10Hz-50kHzTHD (1kHz, 4 Ohm): <0.01%Signal to Noise Ratio: >95dBDimensions: 11 13/16” x 2 3/8” x 12 7/8”PWM Regulated MOSFET Power SupplyBalanced Isolator Input CircuitOversized Screw-Type Power/Ground Terminals4 Channel RCA InputsRCA Outputs (Pass Thru)Speaker Level InputScrew-Type Speaker TerminalsHi-Volt Input Level Control (200mV-6.5V)Selectable Crossover (80Hz, -12dB/Oct.)Pioneer 1-Year Warranty
