PoorManQ45 wrote:You can fit 6.5s or 6x9s in the front doors. You have about 2.5"~3" of clearance.
I'd recommend either the DLS R6A $152 shipped or DLS MS6A $176 shipped. They are both badass speakers and require and amp. For the Amp the Pioneer GM-5300T $99 shipped is a great amp that puts out plenty of power.
I personally would use the same set in both the front and back. Get two of those Pioneer amps. for about $500 you'll have a badass setup.
I really like the Pioneer HU that you've chosen. One thing to note, if you want HD Radio you will have to purchase the GEX-P10HD module for $120 MSRP. So if HD radio is of any importance to you factor the additional cost of the module when comparing the HU to other models.
I really LOVE that the HU has built in HPF and LPF capability. High-Pass Crossover (HPF) 50/63/80/100/125Hz, -12dB/Oct.Subwoofer Crossover (LPF) 50/63/80/100/125Hz, -18dB/Oct., +/-12dB
You have no idea how much that'll improve the sound quality versus using the built in HPF/LPF in most amplifiers..
I also really like the looks of that Head Unit too. Hopefully the Blue light isn't too bright at night. Other then that it's very elegant looking.
Modified by PoorManQ45 at 7:26 PM 2/15/2008
Thank you for the good info.........................I got the Alpine 609's for $82.00 and the Kappas for $64.00 the Pioneer FH-P800BT is running $275. The biggest cost is rewiring everything and dumping the Bose Stuff.I chose that head unit because of all the capabilities, the color and the fact the it does not look too out of place in my 14 yr old Q. I am hoping there is a way to adjust the lighting on the unit.
It will be a couple of weeks before it is all done. It was an rather unexpected thing for my amp to go in a day. So I am running just the one Bose speaker in the rear with until I get the head unit delivered and installed.
The other thing is that I did not want to have to do any customizing or alterations, I have no place to work on my car....Best Buy is doing the install.
Modified by CINNALOCKS at 11:55 AM 2/18/2008
