Infinity Kappa 6.5s coaxials in the s13 door [pics]
Post all your Nissan electronics, car audio and stereo questions here!
mello88
Car: s13
This has been done by many others, but I figured I'd post my pics anyways. If you still have the 4x6 speakers in the front you're missing out on a lot of great midbass and crisp highs -- if you want some much better sounding audio try this out...
Stock on the right. My adapter baffle on the left, made of 1/4" plexiglass. The black stuff is 1/4" foam tape to help prevent rattles and to make a better seal on the door panel:
Here's a closer shot of my adapter baffle:
And installed in the door:
No problems at all with door panel or window clearance with these speakers! They sound amazing -- even being run off my 17wx4 Clarion deck. I am going to buy an amp and upgrade to components soon, but for the time being this is a great mod.
Rex
Car: None
Looks good, but seriously, spend a day or 2 making those (minus speaker mounting holes, as they aren't standard) and you can sell them all day long as a side business.
6 1/2 round speakers sound SOOOOOOOOOO much better that the 4x6's no matter how expensive the 4x6's are.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
is there a BIG difference between true 6.5 coaxials and 6.5 seperates, with crossovers, that can be mounted as coaxials with the tweeters directly over the drivers?????? seems there is a big price difference.
mello88
Car: s13
Rex wrote:Looks good, but seriously, spend a day or 2 making those (minus speaker mounting holes, as they aren't standard) and you can sell them all day long as a side business.
I bought a 36x24 (iirc) sheet of plexi from home depot and made two sets of these adapters, figuring that I could sell a second set to pay for the minor costs (dremel bits, foam tape, plexi, time/gas spent) and just about break even. The second set of blanks I didn't drill any cutouts or bolt holes so it'll work for anyone for any speaker... If anyone would like a pair they could PM me for more information.
If enough people want them or have interest then I would have a batch laser cut...
Knowing what I do now, I still would have just bought an adapter like this off somone if I could have... Sure they're easy and fairly cheap to make but it would have saved me a good deal of time & effort... Plus not everyone owns the tools and has a place to make these.
mello88
Car: s13
nuQ wrote:is there a BIG difference between true 6.5 coaxials and 6.5 seperates, with crossovers, that can be mounted as coaxials with the tweeters directly over the drivers?????? seems there is a big price difference.
If you're asking if components are "worth" the extra money vs coaxials, It really depends on your budget and how much you value your sound . If you're just looking for something to upgrade the stock speakers with, nice 2/3/4way coax 6.5s will make a world of difference and probably be more than enough. But if you're planning on adding much more audio gear (external amps, sub(s), eq, fiberglass/sound deadening, etc) then you should probably go with the best components you can afford.
BTW these are crossed over too, inside each door is a little 2-way passive crossover. They'll take 75w rms (I drive them with my 18Wx4 Clarion CD/MP3 deck) and produce far more bass than the paper trash that they replace!! HTH
PoorManQ45
mello88 wrote: They'll take 75w rms (I drive them with my 18Wx4 Clarion CD/MP3 deck) and produce far more bass than the paper trash that they replace!! HTH
Hold up, so you just replaced the stock speakers with 6.5s? You know, there would have been a big improvement if you just replaced the OEM speakers with aftermarkets speakers of the same size too .
The best OEM speaker is about on par with the worst aftermarket coaxial. This excludes really high end stuff like the Mark Levison Lexus and new Bose systems. But you get the idea
PoorManQ45
Also, that tape that you said you used, it looks like Heater and/or AC duct tape
Where did you get it from and how much did it cost?
Rex
Car: None
PoorManQ45 wrote:Hold up, so you just replaced the stock speakers with 6.5s? You know, there would have been a big improvement if you just replaced the OEM speakers with aftermarkets speakers of the same size too .
Keep in mind he replaced 4x6's with a 6.5, now yes better 4x6's would have made a difference, but the step up form a 4x6 was a smart move.
PoorManQ45
I agree, can you explain why 6.5s are better then 4x6s? Is it just because of the increased size, or is this a circle vs. oval issue?
Rex
Car: None
PoorManQ45 wrote:I agree, can you explain why 6.5s are better then 4x6s? Is it just because of the increased size, or is this a circle vs. oval issue?
See below, but in short sound waves want to be circular and an oval can't create a perfect circular sound wave.
The Physics Classroom wrote:Lesson 3: Behavior of Sound Waves
Interference and Beats
Wave interference is the phenomenon which occurs when two waves meet while traveling along the same medium. The interference of waves causes the medium to take on a shape which results from the net effect of the two individual waves upon the particles of the medium. As mentioned in a previous unit of The Physics Classroom, if two crests having the same shape meet up with one another while traveling in opposite directions along a medium, the medium will take on the shape of a crest with twice the amplitude of the two interfering crests. This type of interference is known as constructive interference. If a crest and a trough having the same shape meet up with one another while traveling in opposite directions along a medium, the two pulses will cancel each other's effect upon the displacement of the medium and the medium will assume the equilibrium position. This type of interference is known as destructive interference. The diagrams below show two waves - one is blue and the other is red - interfering in such a way to produce a resultant shape in a medium; the resultant is shown in green. In two cases (on the left and in the middle), constructive interference occurs and in the third case (on the far right, destructive interference occurs.
But how can sound waves which do not possess crests and troughs interfere constructively and destructively? Sound is a pressure wave which consists of compressions and rarefactions. As a compression passes through a section of a medium, it tends to pull particles together into a small region of space, thus creating a high pressure region. And as a rarefaction passes through a section of a medium, it tends to push particles apart, thus creating a low pressure region. The interference of sound waves causes the particles of the medium to behave in a manner that reflects the net effect of the two individual waves upon the particles. For example, if a compression (high pressure) of one wave meets up with a compression (high pressure) of a second wave at the same location in the medium, then the net effect is that that particular location will experience an even greater pressure. This is a form of constructive interference. If two rarefactions (two low pressure disturbances) from two different sound waves meet up at the same location, then the net effect is that that particular location will experience an even lower pressure. This is also an example of constructive interference. Now if a particular location along the medium repeatedly experiences the interference of two compressions followed up by the interference of two rarefactions, then the two sound waves will continually reinforce each other and produce a very loud sound. The loudness of the sound is the result of the particles at that location of the medium undergoing oscillations from very high to very low pressures. As mentioned in a previous unit, locations along the medium where constructive interference continually occurs are known as anti-nodes. The animation below shows two sound waves interfering construcively in order to produce very large oscillations in pressure at a variety of anti-nodal locations. Note that compressions are labeled with a C and rarefactions are labeled with an R.
Now if two sound waves interfere at a given location in such a way that the compression of one wave meets up with the rarefaction of a second wave, destructive interference results. The net effect of a compression (which pushes particles together) and a rarefaction (which pulls particles apart) upon the particles in a given region of the medium is to not even cause a displacement of the particles. The tendency of the compression to push particles together is cancelled by the tendency of the rarefactions to pull particles apart; the particles would remain at their rest position as though there wasn't even a disturbance passing through them. This is a form of destructive interference. Now if a particular location along the medium repeatedly experiences the interference of a compression and rarefaction followed up by the interference of a rarefaction and a compression, then the two sound waves will continually cancel each other and no sound is heard. The absence of sound is the result of the particles remaining at rest and behaving as though there were no disturbance passing through it. Amazingly, in a situation such as this, two sound waves would combine to produce no sound. As mentioned in a previous unit, locations along the medium where destructive interference continually occurs are known as nodes.
You might remember the popular classroom demonstration involving the interference of two sound waves from two speakers. The speakers were set approximately 1 meter apart and produced identical tones. The two sound waves traveled through the air in front of the speakers, spreading our through the room in spherical fashion. A snapshot in time of the appearance of these waves is shown in the diagram below. In the diagram, the compressions of a wavefront are represented by a thick line and the rarefactions are represented by thin lines. These two waves interfere in such a manner as to produce locations of some loud sounds and other locations of no sound. Of course the loud sounds are heard at locations where ccompressions meet compressions or rarefactions meet rarefactions and the "no sound" locations appear wherever the compressions of one of the waves meet the rarefactions of the other wave. If you were to plug one ear and turn the other ear towards the place of the speakers and then slowly walk across the room parallel to the plane of the speakers, then you would encounter an amazing phenomenon. You would alternatively hear loud sounds as you approached anti-nodal locations and virtually no sound as you approached nodal locations. (As you may have observed, the nodal locations were not true nodal locations due to reflections of sound waves off the walls which tended to fill the entire room with reflected sound. Even though the sound waves which reached the nodal locations directly from the speakers destructively interfered, other waves reflecting off the walls tended to reach that same location to produce a pressure disturbance.)
See an Animation
Destructive interference of sound waves becomes an important issue in the design of concert halls and auditoriums. The rooms must be designed in such as way as to reduce the amount of destructive interference. Interference can occur as the result of sound from two speakers meeting at the same location as well as the result of sound from a speaker meeting with sound reflected off the walls and ceilings. If the sound arrives at a given location such that compressions meet rarefactions, then destructive interference will occur resulting in a reduction in the loudness of the sound at that location. One means of reducing the severity of destructive interference is by the design of walls, ceilings, and baffles that serve to absorb sound rather than reflect it. This will be discussed in more detail later in Lesson 3.
The destructive interference of sound waves can also be used for advantageously in noise reduction systems. Ear phones have been produced which can be used by factory and construction workers to reduce the noise levels on their jobs. Such ear phones capture sound from the environment and use computer technology to produce a second sound wave which one-half cycle out of phase. The combination of these two sound waves within the headset will result in destructive interference and thus reduce a worker's exposure to loud noise.
Interference of sound waves has widespread applications in the world of music. Music seldom consists of sound waves of a single frequency played continuously. Few music enthusiasts would be impressed by an orchestra which played music consisting of the note with a pure tone played by all instruments in the orchestra. Hearing a sound wave of 256 Hz (middle C) would become rather monotonous (both literally and figuratively). Rather, instruments are known to produce overtones when played resulting in a sound which consists of a multiple of frequencies. Such instruments are described as being rich in tone color. And even the best choirs will earn their money when two singers sing two notes (i.e., produce two sound waves) which are an octave apart. Music is a mixture of sound waves which typically have whole number ratios between the frequencies associated with their notes. In fact, the major distinction between music and noise is that noise consists of a mixture of frequencies which have no mathematical order to them and music consists of a mixture of frequencies which have a clear mathematical relationship between them. While it may be true that "one person's music is another person's noise" (e.g., your music might be thought of by your parents as being noise), a physical analysis of musical sounds reveals a mixture of sound waves which are mathematically related.
To demonstrate this nature of music, let's consider one of the simplest mixtures of two different sound waves - two sound waves with a 2:1 frequency ratio. This combination of waves is known as an octave. A simple sinusoidal plot of the wave pattern for two such waves is shown below. Note that the red wave has two times the frequency of the blue wave. Also observe that the interference of these two waves produces a resultant (in green) which has a periodic and repeating pattern. One might say that two sound waves which have a clear whole number ratio between their frequencies interfere to produce a wave with a regular and repeating pattern; the result is music.
Another simple example of two sound waves with a clear mathematical relationship between frequencies is shown below. Note that the red wave has three-halves the frequency of the blue wave. In the music world, such waves are said to be a fifth apart and represent a popular musical interval. Observe once more that the interference of these two waves produces a resultant (in green) which has a periodic and repeating pattern. It should be said again: two sound waves which have a clear whole number ratio between their frequencies interfere to produce a wave with a regular and repeating pattern; the result is music.wave pattern
Finally, the diagram below illustrates an example of noise. The diagram shows two waves interfering, but this time there is no clear mathematical relationship between their frequencies (in computer terms, one has a wavelength of 37 and the other has a wavelength 20 pixels). Observe (look carefully) that the pattern of the resultant is neither periodic nor repeating. The message is clear: if two sound waves which have no simple mathematical relationship between their frequencies interfere to produce a wave, the result will be an irregular and non-repeating pattern; this is "noise."wave pattern
A final application of music to the world of physics pertains to the topic of beats. Beats are the periodic and repeating fluctuations heard in the intensity of a sound when two sound waves of very similar frequencies interfere with one another. The diagram below illustrates the wave interference pattern resulting from two waves (drawn in red and blue) with very similar frequencies. A beat pattern is characterized by a wave whose amplitude is changing at a regular rate. Observe that the beat pattern (drawn in green) repeatedly oscillates from zero amplitude to a large amplitude, back to zero amplitude throughout the pattern. Points of constructive interference (C.I.) and destructive interference (D.I.) are labeled on the diagram. When constructive interference occurs, a loud sound is heard; this corresponds to a peak on the beat pattern (drawn in green). When destructive interference occurs, no sound is heard; this corresponds to a point of no displacement on the beat pattern. Since there is a clear realtionship between the amplitude and the loudness, this beat pattern would be consistent with a wave which varies in volume at a regular rate.wave pattern
The beat frequency refers to the rate at which the volume is heard to be oscillating from high to low volume. For example, if two complete cycles of high and low volumes are heard every second, the beat frequency is 2 Hz. The beat frequency is always equal to the difference in frequency of the two notes which interfere to produce the beats. So if two sound waves with frequencies of 256 Hz and 254 Hz are played simultaneously, a beat frequency of 2 Hz will be detected. Beats were produced in a classroom demonstration using two tuning forks. Though the tuning forks were identical, the frequency of one of the forks was lowered by wrapping one of the tines with a rubber bands. The result was that the two tuning forks produced sounds with slightly different frequencies which interfered to produce detectable beats. The human ear is capable of detecting beats with frequencies of 7 Hz and below.
A piano tuner frequently utilizes the phenomenon of beats to tune a piano string. She will pluck the string and tap a tuning fork at the same time. If the two sound sources - the piano string and the tunng fork - produce detectable beats then their frequencies are not identical. She will then adjust the tension of the piano string and repeat the process until the beats can no longer be heard. As the piano string becomes more in tune with the tuning fork, the beat frequency will be reduced and approach 0 Hz. When beats are no longer heard, the piano string is tuned to the tuning fork; that is, they play the same frequency.
Important Note: Many of the diagrams on this page represent a sound wave by a sine wave. Such a wave more closely resembles a transverse wave and may mislead people into thinking that sound is a transverse wave. Sound is not a transverse wave, but rather a longitudinal wave. Nonetheless, the variations in pressure with time take on the pattern of a sine wave and thus a sine wave is often used to represent the pressure-time features of a sound wave.
PoorManQ45
Excellent post, but it didn't really deal with the issue at hand
Yes sound waves are USUALLY circular, but they are also conical. And you must remember that at different frequencies the sound waves have varying directivity patterns. The oval/elliptical driver, if designed properly, can be used to decrease the directivity problem, ie. increased the dispersion radius.
Have you ever seen a pair of old Nakamichi 3-ways? I remember seeing one awhile back that actually used a 4x6 as the midrange driver. I was a little confused by that, but it had excellent ratings/reviews. I'll try to find it if I can.
Also, I'll take a picture of some dispersion patterns just for the heck of it
Rex
Car: None
Yes not ALL sound waves are perfectly circular, but lets make sure you aren't comparing a stock Nissan 4x6 and a Nak 4x6??
mello88
Car: s13
IMO 6.5s always sound better than 4x6s. The front actually had some POS upgraded 4x6 speakers but they still sounded like trash. I doubt that new 4x6s would sound nearly as nice as new 6.5s -- coax or seperates. The rear paper speakers had NO surround, they had completely disentigrated from the Sun/heat/UV... I would say that the 6.5s have better mid/bass response due largely to the fact that they have more cone area:
4x6 = 2*3*pi = 18.84sq inches6.5" = pi*(3.25*3.25) = 33sq inches
So if my math is correct, a 6.5" driver has 75% more surface area than a 4x6...
Someone asked about the tape: you're correct it's used for wrapping pipes in the cold weather! I got it from Home Depot, it was $5 or so for a big roll of it. It seems to work well for helping the seal and damping any resonance of the plexi...
nuQ
are your 6.5's the infinity kappa 62.5i speakers???????
PoorManQ45
Haha, I knew you were going to post here Nuq .
note that 6.5s most definately WILL fit in the Q45 if you still have doubts. I just checked on my Q today and there is plenty of room
mello88
Car: s13
The 63.5i yesI think the 62s are 2way and the 63s are 3 way... Do you have the same speakers?
nuQ
no,,,,,just trying to put together a system and find the best & most reasonable components. always liked the kappa line. used to have mb quart seperates and loved them. i hear alot of good things about boston accoutics too.........
mello88
Car: s13
They're good speakers for the money. I got a deal on them thru ebay.
PartsExpress has a lot of good quality drivers, you should check them out: http://www.partsexpress.com/we...ID=30
Chingon
Car: 1991 and 1992 hatchbacks
bump...
How bad does the stock grill interfere w/these? I have a set of polk components I may drop in.
xckid
Car: 2004 Chevy Blazer ZR2
What about the door panel did you have to cut it and what do you use to cover it im sure people try to poke at it
mello88
Car: s13
I don't see any interference with mine... Components should have even more clearance.
mello88
Car: s13
xckid wrote:What about the door panel did you have to cut it and what do you use to cover it im sure people try to poke at it
No need to cut the door panel. It uses the factory grill and looks 100% stock, you can't tell anything is upgraded until you play music... There is no need to cut your door panels for this upgrade. If you're installing components you should flush the tweeter up higher, above the window crank below the glass on the front of the panel near the dash. For that you usually just use a hole saw and drop the tweeter+cup in.
Rex
Car: None
mello88 wrote:Why jack my thread to sell your stuff, go make a new thread for your speakers in 'for sale'
I deleted both, his post and your quote. Didn't realize he was trying to sell them, just thought he was making a reco.
PoorManQ45
I didn't realize that you're a mod of all forums? WHen did that happen? I thought you were confined to your cage that we like to call "Infiniti General?
Rex
Car: None
PoorManQ45 wrote:I didn't realize that you're a mod of all forums? WHen did that happen? I thought you were confined to your cage that we like to call "Infiniti General?
Car Audio was done awhile back, and then "global" when we had a rush of spam, as I'm on most days.
Don't hate .
PoorManQ45
I will hate. When do I get offered a position like that. Or rather, how much is it going to cost me
Fmr12B
Car: 1999 Contour SVT
Hey Mello,
Do all the S13 owners on here a huge favor and copy the template onto a piece of paper and scan it in at 100% of size. I've done this with my Contour SVT and it worked beautifully.
I need to upgrade my door speakers and since I'm living in an Apt. I can send the template off to my pops and he will cut a fiberboard template for me.
If you can do this props!
Chingon
ditto. I was gonna ask the same thing. hell if someone can just draw it on a piece of paper and mail it this way, i'll pay for the postage.
wangless
Car: '02 MBP WRX
I can make templates if you want, I just need to find the old speakers. I can attempt to make them out of wood again also.
wangless
Car: '02 MBP WRX
Not sure how this should work, but go here...
http://nissaninfiniticlub.net/...13000
Use the orginal screws that hold in the old speaker bracket for the circles on the outside of the template. The inside ones were for my own speaker.
And here is how mine came out with some MB Quartz components
Sorry if the scan is TOO BIG or what not. I just bought a 3 in 1 and just clicked scan. Haven't had time to mess with the settings. And its an old template, I can't seem to find my orginal speakers at the moment.
