Infinity Kappa 42.71 in front door of 94Q
CINNALOCKS
Car: 1994 Q45A Converted/ Burgundy & Tan /TokicoBlues /JWFSTB/ Silverstars/ Upgraded ECU
I want a pair of the Infinity Kappa 42.71 speakers to replace the factory Bose speakers in the front door. The Kappas have a 1 13/16" Mounting Depth and 3 7/16" Cut Out Diameter.
I am wondering before I order them if they will work without alteration. I am going Alpine 609's in the rear and the PIONEER FH-P800BT Headunit.
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
zer...05927
This might help.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
don't forget that the 1.1L volume of the front speaker box is tuned to a 4inch driver.sure you can stuff a bigger speaker in, and it might sound pretty good. but, you'll be starving it for acoustic mass.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
did you decide to keep your bose speaker amps? they will work well as long as you choose a high sensitivity speaker---something >90 dBA/1 watt.
T45
Car: King Kong powered Z32
Kappas are very bright. Expect lots of highs.
CINNALOCKS
T45 wrote:Kappas are very bright. Expect lots of highs.
Yeah I like the highs in the front and the alpine 609's will cover the lows in the rear. I am thinking I will disconnect the tweeters in the pillar if I am getting to much of the highs........but after being in it and hearing it there is always the thought to readjust somethings.
CINNALOCKS
mxr662 wrote:zer...05927
This might help.
Thanks but I have no where to do any work on my car. So it will all be done at the shop. Meaning I am not saving any bucks so I do not want to do any alterations at this point. If the 4" Infinity's do not work as well as I assume, then when the weather changes I can consider doing a further upgrade. Indiana weather does not allow us to do much outside in the winter.
CINNALOCKS
3Q Jay wrote:did you decide to keep your bose speaker amps? they will work well as long as you choose a high sensitivity speaker---something >90 dBA/1 watt.
No the Bose amps are too restrictive. I want to go with another system that is easier to wire and rewire. By the time I buy used amps and install, then wire the new speakers to front and rear..................If one of the old 14 yr old amps go out again I am still needing to find used amps and repeat the same old sh--! So later for all the Bose stuff and if something goes awry I can fix it very easily by replacing the speaker.....not having to find and pay for, harder to get Bose amps that go bad.
