infinititech1: need your help with power door locks.
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
thelakeshow2k
Car: 2003 infiniti g35 coupe red
what's the part name that controls the power door locks? seems like it sticks when it's hot outside. would push power lock on door or remote but wouldn't lock/unlock but would try to. seemed to work when it was cold? any ideas? thanks.
infinititech1
is it doin it on all the doors?? cause if like just one door is lazy usually it would be the door lock actuator
thelakeshow2k
it's a coupe, so if the driver door doesn't work, neither does the passenger door. does it look like i need to replace a part or spray some lube on parts????
infinititech1
ok...what exactly is it doin? do the door locks move at all? do they make noise? do you hear anything when you push the buttons?
thelakeshow2k
when it's acting up..... i push the lock button (or the remote) to lock or unlock and the knob moves but maybe only 1/4 - 1/3 of the way and stops.
infinititech1
sounds like door lock actuator to me...i replaced a few of them
thelakeshow2k
infinititech1 wrote:sounds like door lock actuator to me...i replaced a few of them
is it simple enough for me to replace. is it as easy as unplugging the old one and plugging in the new part??? it might be the best time for me to do it (if i can) because the door panel is off right now.
infinititech1
well...its not easy...and not hard. just hope you have small hands. when you open your door...look on the side where it latches to the body...the 3 screws you see hold on the actuator. but its also connected to the outside door handle. its also what those 2 cables that connect to the door panel go to. you would need torx head screw drivers to remove the lock cylinder thats connected to it
hope this helps
csguy0
Car: 2004 G35 6MT
Hey I am having trouble with mine also... I decided to take my door apart and see what is going on inside there... It looks like to really get in there and take that thing out... I will have to take the driver side window out. Any tips on where I can buy a new solenoid for cheap? Also are there replaceable parts inside the unit that I could tinker with? I'm still in disbelief that it just stopped working. I added you to my AIM buddy list... hoping to catch you on there as this is an old thread.
I'm online with daveydonn
Thanks,
David
sxmtrevor
Car: 2000 g20 t
seen this problem over 100 times its the door lock actuator and lock assembly. its one unit. i work at the infiniti dealer and as far as i know its only sold at the dealer. easy to do if you've done it before. if not good luck
csguy0
Car: 2004 G35 6MT
Anywhere to get these cheap(er) than what the dealer charges?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
check
http://www.infinitipartsonline.com
i have found this to be cheaper for most everything.
scubasteveorino
Hi guys,
I am also having the same problem with my 03 Coupe. The passenger door is getting 'stuck' where the lock barely moves when I use the keyless or use the door lock/unlock button. You're saying I need the entire lock assembly, correct? Looks like the part costs around $150 online.
The replacement requires removing the entire door panel, correct?
Thanks for your help guys. Hopefully I can replace this myself.
Return to “G35 and G37 Interior, Exterior and Audio”
