infiniti
yowwaa30
my infiniti j30 has a shifting problem,when i am driving below 40mph i get stuck between gears when i accelerate it sounds like the engine is racing,and i have to pull over and restart the car,can anyone give me some advice of what can it be
yodawill2000
Car: 94 Infiniti J30
Check the ATF level asap.have you ever flushed the fluid in your transmission ??Filter change ??More data is needed.
driverdriver
Car: NICO's longtime resident Canuck!!!
Welcome to NICO!!!
The symptoms you describe are almost exactly what happens when the transmission revolutions sensor starts to go. I'm pretty confident you need a rev sensor. Check your ECU for the code to be sure (the "how to" for checking your ecu is written up as a "stuck" item and stuck on main J30 forum page).
