LongBeachCoupe wrote:I think he took a physical Infiniti start button and put it in the car.
To do that, pull down the underside of your dash on the right hand side (just yank) then pull out the instrument cluster (just pull)... then the start button is held in by a wire harness, and one of those tab connectors.
To change the color of the light is a soldering job... something that Surman has been doing...
The accent lights however.. that im interested in seeing what was done!
ill do a full write up on it, hopefully i can have it up by tomorrow or monday.but you can just pop the start button out just using a screwdriver. the actual unit is 3 pieces: the button, the chrome shroud, and the lights in the back. the you just unplug the light part and plug into your car. easy as pie. no dash removal.
