infiniti raises parts prices sharply this month
qship96
Car: 1996 Infiniti Q45
just ordered rear pads from Cheryl- price went up 20 percent since march! she said major price increase from nissan effective april 1st! on all nissan/infiniti parts- website being updated with new prices.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I wonder why this is happening?
RobertsnewQ
THey need to pay for their move to Tennessee
Seriously, they've got to hire around 2000 people... Lots of relo expenses for Nissan.
Apparently theyre trying to get me to switch brands.
Used '03 CTS's starting at $14k.Used '95 540's for $5k.
Things that make you go "hmmm."
elwesso
2007 BMW M Coupe
Hell you can get E39 540i 6 speeds for around 8k......
Q45tech
And a new BMW transmission will cost about that. Always useful to compare Ebay engine, transmission, parts prices to understand how much more European parts prices are vs economical Japanese.
If you want cheap prices and cheap parts buy American until Delphi renegotiates its prices after Bankruptcy.
BMW parts prices arent that bad at all, especially the E34. They're cheaper in many cases. The difference between German and Japanese parts costs is horribly exaggerated.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Jesda wrote:BMW parts prices arent that bad at all, especially the E34. They're cheaper in many cases. The difference between German and Japanese parts costs is horribly exaggerated.
True. It's just the labor on certain engines that is the pita... but then again I do drive a Q45
defrag010
Q45tech wrote:And a new BMW transmission will cost about that. Always useful to compare Ebay engine, transmission, parts prices to understand how much more European parts prices are vs economical Japanese.
I know on Z3's, they use 4l30E's.. do any other bimmers use GM trannies?
elwesso
2007 BMW M Coupe
I tihnk if you compared average dealership prices between say a 94 540 and a 94 Q45 itd be a close comparison, but the bimmer parts more expensive.
Seesm the parts that fail often are expensive and the parts that dont fail are cheap.
With non-dealer online sources like Pelican and Bavarian, its the same as or cheaper than Scottsdale.
qship96
I would bet part of the price increase is due to higher transportation costs due to fuel prices increases being passed on from suppliers.
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
qship96 wrote:just ordered rear pads from Cheryl- price went up 20 percent since march! she said major price increase from nissan effective april 1st! on all nissan/infiniti parts- website being updated with new prices.
I just ordered an upper front susp. link. It went up from $94 to $99.5% or so increase there.
Last April 1st the price of OEM struts for the G50 about doubled ... a 100% increase! The price increases are not spread evenly across all parts.
Q45tech
By now I would expect that Nissan had to order a new production run of oem shocks for replacements, as what ever was made extra in 1989 and 1993 was probably exhausted........empty warehouses in Japan.
What do you think inflation has been in the last 17 and 13 years..
36% in dollars plus the yen depreciation is 20% so 56% plus dealer markup on cost ~~100%. Sounds normal to me.
I'm sure the production cost are higher as the number of shocks made were fewer than needed for a new car production plus spares.
yodawill2000
Car: 94 Infiniti J30
Man ..I wish I would have bought the struts for my J30 already .Those things are way high .. and no alternative source .. ouch .
breaksr
I went to order a water pump: $112 and the Tension Rod bushings: $25 each. Seems higher then I expected. Water pump is $80 at Advance auto. Can I buy the bushings other then the dealer? I'm getting tired of the urethane bushings since the ride is just too hard.
Dont buy an aftermarket water pump.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
squeefoo
1999 Infiniti I30
...and if you thought that was scary: crank up the presses!!!!
RobertsnewQ
There are two other things:1. The G50 president went out of production in '02, so now even those cheap mechanical parts are depleted.
2. This is bad news - ask the Z32 guys. Nissan loves to increase the price of a part they are about to discontinue. Usually they increase it by 20% or so, then it's gone a year later.
Q45tech
YEP! I'm surprised that they still stock parts for 90-93 luckily the 94-96 used nearly/or identical suspension/rotors/pads/transmission/shaft.
Why I have a spare room full of personal parts.
Just swapped out my spare tire for a 96 version [at least it's 6 years newer].
breaksr
After market water pump? Too late it's already in the car. Lifetime warranty. Is there a problem with them?
Aftermarket water pumps tend to burst spontaneously (I've seen it happen, crazy stuff) or bearings will fail early on. Some brands are better than others.
A shop put an aftermarket pump in my last Q and it has, so far, gone 40,000 miles and 3 years. However, thats not exactly a long time.
Its not a hard part to install anyway so if its already in, don't let it keep you up at night. Just make sure your AAA membership is current.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
breaksr wrote:After market water pump? Too late it's already in the car. Lifetime warranty. Is there a problem with them?
Aftermarket impellers and bearings tend to be the cheapest the aftermarkdet rebuilder can find because everyone at Autozone and Pep Boys is a price point buyer.
